20 years agobuilding custom uClinux on DE2
hello, i downloaded the prebuild uclinux from nioswiki and that worked fine for me, but i need to put my own software there to be run and so i got to compile myself everything. i can compi...
20 years agoMatheus,
Are you using the NIOS IDE? If that's the case, you should create a File System Project in order to it work. I recommend you to follow all steps presented in nios2colinux (http://nioswiki.jot.com/wikihome/operatingsystems/nios2colinux). It worked fine for me. I had some problems myself using NIOS IDE, but everything worked with this tutorial. After that, I could make the NIOS IDE work, too. Good Luck Alair
