19 years agoBuilding an application
I'm trying to build ipsec-tools using buildroot.
After doing some patches on config.sub to include host nios2 I run make and got some errors: main.c: In function `main': main.c:221: warning: implicit declaration of function `daemon' make[4]: ** [main.o] Erro 1 make[4]: Leaving directory `/home/marcelo/buildroot/build_nios2/ipsec-tools-0.6. 6/src/racoon' make[3]: ** [all-recursive] Erro 1 make[3]: Leaving directory `/home/marcelo/buildroot/build_nios2/ipsec-tools-0.6. 6/src' make[2]: ** [all-recursive] Erro 1 make[2]: Leaving directory `/home/marcelo/buildroot/build_nios2/ipsec-tools-0.6. 6' make[1]: ** [all] Erro 2 make[1]: Leaving directory `/home/marcelo/buildroot/build_nios2/ipsec-tools-0.6. 6' make: ** [/home/marcelo/buildroot/build_nios2/ipsec-tools-0.6.6/src/setkey/setke y] Erro 2 I tried to compile different versions of buildroot an different versions of ipsec-tools and I got the same errors. Can someone please help me?!4 Replies
I edited unistd.h on $STAGING_DIR/include directory and saw this:
# ifdef __ARCH_USE_MMU__ /* Put the program in the background, and dissociate from the controlling terminal. If NOCHDIR is zero, do `chdir ("/")'. If NOCLOSE is zero, redirects stdin, stdout, and stderr to /dev/null. */ extern int daemon (int __nochdir, int __noclose) __THROW __wur;# endif Then I comment the lines that use this function in the program but I get the same error with the function fork. Can someone please help me? What I can do? - Altera_Forum
fork is not allowed with MMU less architectures.
You can try: --with-cflags="-D__uClinux__ -DUSE_VFORK -Dfork=vfork" May be it compiles then but if it works is not for sure, in most cases vfork can be used instead of fork, I think the difference is that in case of vfork the child shares code and memory with the parent. - Altera_Forum
Thanks for your answer nacide.
I had already realized this and used the solution that you propose. But I didn't use "-DUSE_VFORK". I didn't need it. Then I had a lot of problems after this and I finally compiled it sucessfully. I'm thinking to post it on the Wiki page to help other users. Thanks anyway! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif - Altera_Forum
You should definitely put it on the wiki ...
