MarkDP
1 year agoBuilding a NiosV BSP using Ashling Riscfree CMake flow fails to compile HAL in Intel code.
I am seeing the following error when building the BSP for NiosV. The build failure is in the Altera HAL under HAL/inc/io.h when trying to build the macro for the 32-bit IOWR as follows: Line 125 wri...
tehjingy_Altera
1 year agoHi
Could you try regenerating the BSP and Cmake List and compile your project?
Jingyang, Teh
