21 years agobuild uclinux kernel problem
hello everyone : I download Linux 2.6 Distribution for Nios II from this website and installed to my computer, I created a linux kernel project follow the quick_start_guide.pdf, when I build t...
21 years agoHello everyone,
I have a problem similarly to Sarah problem. In particularly, during the building of the project, I’ve received the error message: Kind Status Priority Description Resource In Folder Location Error *** output directory "/cygdrive/d/altera/kits/nios2/bin/eclipse/workspace/kernel_1s10/build" does not exist. Stop.[Makefile] kernel_1s10 line 92 Is it possible that the problems depend on that I have installed Quartus on D disk? Moreover, the dos window is not as showed in the “microtronix nios II quick starting guide” during the Kernel configuration. I’ve tried to write “umount: /usr/lib” in the niosII sdk shell but the message is “umount: /usr/lib: No such file on directory” although I can the directrory “ ls /usr/lib”. Have I to reinstall the quartus in the “c:\altera\quartus41 directory”? Have I to copy the “"D:\altera\kits\nios2\” in another directory? Can someone help me? Thank you.
