21 years agobuild uclinux kernel problem
hello everyone : I download Linux 2.6 Distribution for Nios II from this website and installed to my computer, I created a linux kernel project follow the quick_start_guide.pdf, when I build t...
21 years agoOpen up a Nios II SDK Shell and give the command: "umount /usr/lib" and after that try again.
This fixed the problem for me. This problem has been encountered before and if the trick above does not help you, you can check out the answers I got when I asked about this in the General discussions. (Search general discussions for "Problem configuring kernel" and make sure you include posts older than 30 days too) -Tervis
