19 years ago
build uclinux error
THANKS
I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busybox-20060320.tar.bz2,uClibc-20060320.tar.bz2 AND buildroot-20060320.tar.bz2
,then I place this files in ~/download instead of WGET commond.
COULD YOU HELP HOW TO MODIFY THE BUID FILE:
# !/bin/bash# rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source
cd ~/download
mkdir mx140
cd mx140# convert the crlf with unzip -a
echo "prepare kernel source"
unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix
cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~
cd ~/linux-2.6.x
patch -p0 <~/download/kernel.diff
cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains
mkdir ~/apps
cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps
cd ~/apps
patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source
cd ~/download
echo "prepare uClinux-dist source"
wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2)
cd ~
tar jxf ~/download/uClinux-dist-20051110.tar.bz2
cd ~/uClinux-dist
patch -p0 <~/download/uClinux-dist.diff
touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab# download buildroot snapshot
cd ~/download
SNAPSHOT=20060320
rm -f buildroot-snapshot.tar.bz2 uClibc-snapshot.tar.bz2 busybox-snapshot.tar.bz2 # wget -N http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2)# wget -N http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2 (http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2)# wget -N http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2)
ln -s buildroot-$SNAPSHOT.tar.bz2 buildroot-snapshot.tar.bz2
ln -s uClibc-$SNAPSHOT.tar.bz2 uClibc-snapshot.tar.bz2
ln -s busybox-$SNAPSHOT.tar.bz2 busybox-snapshot.tar.bz2
cd ~
tar jxf ~/download/buildroot-snapshot.tar.bz2
cd ~/buildroot
ln -s ~/download dl# patches for configs, add elf2flt to busybox
patch -p0 <~/download/buildroot.diff
make oldconfig
make# clean headers for uClinux-dist
cd ~/buildroot/build_nios2/staging_dir/include/linux
rm config.h autoconf.h
touch config.h autoconf.h# prepare root fs
rm -rf ~/rootfs
mkdir ~/rootfs
cp -a ~/buildroot/build_nios2/root/* ~/rootfs
cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list
rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot
cp ~/download/inittab etc
    --- Quote Start ---
    originally posted by nwpu_zhf2004@May 29 2006, 06:14 PM
    thanks,i don&#39;t use fedora and vmware ,i only use the red hat 9.0 on pc directly ,pls help me !!!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15656)
    --- quote end ---
    --- Quote End ---
    fedora core is redhat linux.
    cd into your redhat CD&#39;s RedHat/RPMS ,
    rpm -Uvh ncurses*.rpm
    [root@localhost RPMS]# rpm -Uvh ncurses*.rpm
    warning: ncurses-5.3-4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
    Preparing... # ########################################## [100%]
    package ncurses-5.3-4 is already installed
    then i execute the command:make menuconfig
    this is the information :
    [wangdengke@localhost uClinux-dist-test]$ make menuconfig
    config/mkconfig > config.in
    /bin/sh: line 1: config.in: &#26435;&#38480;&#19981;&#22815;
    make: *** [config.in] Error 1
    thx!
    dear all,
    I executed the kernal config,the error information is below,could you help me?
    [root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- hwselect SYSPTF=cpu.ptf
    no emulation specific options.
    RUNNING hwselect
    --- Please select which CPU you wish to build the kernel against:
    (1) cpu_0 - Class: altera_nios2 Type: s Version: 5.0
    Selection: 1
    --- Please select a device to upload the kernel to:
    (1) flash
    Class: altera_avalon_cfi_flash
    Selection: 1
    --- Please select a device to execute kernel from:
    (1) number_device_0
    Class: number_device
    (2) sdram
    Class: altera_avalon_new_sdram_controller
    Selection: 2
    --- Summary using
    PTF: cpu.ptf
    CPU: cpu_0
    Device to upload to: flash
    Program memory to execute from: sdram
    --- Settings written to /home/wangdengke/linux-2.6.x/arch/nios2nommu/hardware.mk
    then execute :
    [root@localhost linux-2.6.x]# make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig
    CHK include/linux/version.h
    UPD include/linux/version.h
    SYMLINK include/asm -> include/asm-nios2nommu
    HOSTCC scripts/basic/fixdep
    /bin/sh: line 1: gcc: command not found
    make[2]: *** [scripts/basic/fixdep] Error 127
    make[1]: *** [scripts_basic] Error 2
    make: *** [include/linux/autoconf.h] Error 2
    It looks like that you didn&#39;t select software development package during redhat linux installataion.
    You need to install gcc. Try "gcc -v", if not work, use rpm to install gcc.
    NOTE, you should NOT cd linux-2.6.x in uClinux-dist to build kernel.
    (This is different from the old buildroot guide)
    READ the WIKI, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
    You should do all the make commands in ~/uClinux-dist-test dir.
    OR, you should backup your data, and reinstall fedora core 5 with software development packages selected during installation.
