20 years agobuild uclinux error
THANKS I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busyb...
20 years ago[root@localhost RPMS]# rpm -Uvh ncurses*.rpm
warning: ncurses-5.3-4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e Preparing... # ########################################## [100%] package ncurses-5.3-4 is already installed then i execute the command:make menuconfig this is the information : [wangdengke@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in /bin/sh: line 1: config.in: 权限不够 make: *** [config.in] Error 1 [wangdengke@localhost uClinux-dist-test]$ thx!
