20 years agobuild uclinux error
THANKS I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busyb...
20 years agoIt looks like that you didn't select software development package during redhat linux installataion.
You need to install gcc. Try "gcc -v", if not work, use rpm to install gcc. NOTE, you should NOT cd linux-2.6.x in uClinux-dist to build kernel. (This is different from the old buildroot guide) READ the WIKI, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist) You should do all the make commands in ~/uClinux-dist-test dir.
