16 years ago
Build the Linux image in uClinux-dist dir
hello,
i would to Build the Linux image in uClinux-dist dir
in nios2-linux/uClinux-dist
i execute de follow commande
>> make menuconfig
but the list of errors appear :
find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig
config/mkconfig > Kconfig
CC=cc CXX=c++ make -C /opt/altera9.1sp1/nios2-linux/uClinux-dist/config/kconfig mconf
make[1]: entrant dans le répertoire « /opt/altera9.1sp1/nios2-linux/uClinux-dist/config/kconfig »
cc -DCURSES_LOC="<curses.h>" -c -o mconf.o mconf.c
Dans le fichier inclus à partir de mconf.c:27:
lxdialog/dialog.h:32:20: erreur: curses.h : Aucun fichier ou dossier de ce type
In file included from mconf.c:27:
lxdialog/dialog.h:97: erreur: expected specifier-qualifier-list before ‘chtype’
lxdialog/dialog.h:187: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:193: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:195: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:196: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:197: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:198: erreur: expected ‘)’ before ‘*’ token
lxdialog/dialog.h:200: erreur: expected ‘)’ before ‘*’ token
mconf.c: In function ‘conf’:
mconf.c:610: erreur: ‘KEY_MAX’ undeclared (first use in this function)
mconf.c:610: erreur: (Each undeclared identifier is reported only once
mconf.c:610: erreur: for each function it appears in.)
mconf.c: In function ‘conf_choice’:
mconf.c:761: erreur: ‘KEY_MAX’ undeclared (first use in this function)
make[1]: *** [mconf.o] Erreur 1
make[1]: quittant le répertoire « /opt/altera9.1sp1/nios2-linux/uClinux-dist/config/kconfig »
make: *** [/opt/altera9.1sp1/nios2-linux/uClinux-dist/config/kconfig/mconf] Erreur 2
1 Reply
