21 years agoBuild Problems..unrecognized instruction
Hi... I'm trying to merge Nios/quartus hardware with software. File structure is: C: Project_File Software (this contains all the C code, etc) Quartu...
21 years agoYou've given me a clue here....
At one point I used legacy components and therefore checked the "legacy SDK support" box on the "More "CPU_0 settings" panel. I no longer use the legacy components, but it seems the files don't get erased. Should I simply delete the cpu_0_SDK folder from the library? (I'll give that a try pending a reply) Thanks!
