21 years agoBuild Outputs
Hello: I've created a NIOS II IDE Project. I build my main.c which contains the simple Hello World porgram with no errors. The IDE keeps running and generated the following "error" mess...
21 years ago --- Quote Start --- originally posted by nios_xx@Oct 25 2004, 07:18 PM i have the same question. just like this:
kind status priority description resource in folder location
errorâ *** [ext_flash.flash] error 5 hello_world_1â
errorâ 32 am - (??) elf2flash: error generating flash file, exiting[oct 26, 2004 8] hello_world_1â line 10
errorâ 32 am - (??) elf2flash: error reading boot copier[oct 26, 2004 8] hello_world_1â line 10
errorâ 32 am - (??) elf2flash: read error: file not found: /boot_loader_cfi.srec[oct 26, 2004 8] hello_world_1â line 10
i dont understand the "file not found: /boot_loader_cfi.srec", because the file boot_loader_cfi.srec is really there! --- Quote End --- @nios_xx: I had maybe the same problem as you. After hours of searching http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I found out that I had a different (light) version of cygwin1.dll on my system (in my case from OpenSSH). After I have deleted it, the building-process from the IDE always aborted with "cygwin1.dll not found". After that I had the reinstall Quartus AND Nios II -> Now it works fine. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif Thomas entner electronics (http://www.entner-electronics.com)
