20 years agobuild nios2-elf-gcc with fedore4
Hi, I try to build the compiler tools with fedora4. Binutils compiled and installed well. Following error on the screen when trying building gcc : checking whether byte ordering is big...
20 years agoI checked the altera's config by "strings nios2-elf-c++.exe".
There is no problem in your config. But they didn't have libstdc++ ... Do you use libstdc++ ? I am still checking... http://gcc.gnu.org/install/ (http://gcc.gnu.org/install/)
