20 years agobuild nios2-elf-gcc with fedore4
Hi, I try to build the compiler tools with fedora4. Binutils compiled and installed well. Following error on the screen when trying building gcc : checking whether byte ordering is big...
20 years agoI am trying with gcc32 and buildroot to gcc3.4.5.
The error message was from an improper def in the config.sub in gcc source, I fix it toIndex: package/gnuconfig/config.sub
--- package/gnuconfig/config.sub (revision 13473)
+++ package/gnuconfig/config.sub (working copy)
@@ -299,8 +299,8 @@
basic_machine=mt-unknown
nios2 | nios2-* | nios2 | nios2-*)
- basic_machine=nios2-altera
- os=-none
+ basic_machine=nios2-uclibc
+# os=-none
# We use `pc' rather than `unknown' Then it can compile some libstdc++, but stopped at from /home/jack/buildroot/toolchain_build_nios2/gcc-3.4.5/libstdc++-v3/src/allocator.cc:35:
/home/jack/buildroot/toolchain_build_nios2/gcc-3.4.5-final/nios2-linux-uclibc/mno-hw-mul/libstdc++-v3/include/nios2-linux-uclibc/bits/c++locale.h: In function `int std::__convert_from_v(char*, int, const char*, _Tv, int* const&, int)':
/home/jack/buildroot/toolchain_build_nios2/gcc-3.4.5-final/nios2-linux-uclibc/mno-hw-mul/libstdc++-v3/include/nios2-linux-uclibc/bits/c++locale.h:103: error: `snprintf' is not a member of `std' I will try other gcc 3.4.x.
