19 years agobuild kernel errors (follows UClinuxDist in Wiki)
hi. i am a beginner on uclinux and i followed the UClinuxDist to build the uclinux kernel, but it turned out some errors. ********************************************************** >make vendor_...
19 years ago --- Quote Start --- originally posted by hippo@Apr 4 2007, 10:28 AM check if you have the "gawk" command with,
which gawk
or check if you have it in /usr/bin or /bin dir.
which linux distro do you use? have you installed devolopment packages?
if you are new to linux, i would suggest centos 4.4.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22799)
--- quote end ---
--- Quote End --- I have it in /usr/bin dir, but when i make romfs: make[2]: Entering directory `/home/nios/download/uClinux-dist/user/boa' for i in src ; do make -C $i romfs || exit ; done make[3]: Entering directory `/home/nios/download/uClinux-dist/user/boa/src' romfs-inst.sh /bin/boa cp: stat‘boa’失败: 没有那个文件或目录 make[3]: *** [romfs] 错误 1 make[3]: Leaving directory `/home/nios/download/uClinux-dist/user/boa/src' make[2]: *** [romfs] 错误 2 make[2]: Leaving directory `/home/nios/download/uClinux-dist/user/boa' make[1]: *** [romfs] 错误 2 make[1]: Leaving directory `/home/nios/download/uClinux-dist/user' make: *** [romfs.subdirs] 错误 1
