19 years agobuild kernel errors (follows UClinuxDist in Wiki)
hi. i am a beginner on uclinux and i followed the UClinuxDist to build the uclinux kernel, but it turned out some errors. ********************************************************** >make vendor_...
19 years agoCheck if you have the "gawk" command with,
which gawk Or check if you have it in /usr/bin or /bin dir. Which Linux distro do you use? have you installed devolopment packages? If you are new to Linux, I would suggest CentOS 4.4.
