20 years agoBuild "hello world" example fails
We have a problem here with the NIOS II 5.1. After installing I tried to build the simple hello_world example and got the following:# ##################################################### **** Incremental build of configuration Debug for project hello_world_0 **** make -s all Creating generated_all.mk... c:/altera/quartus51//sopc_builder/bin/sopc_builder: not found make: *** [C:/altera/kits/nios2_51/examples/verilog/niosII_cycloneII_2c35/standard/software/hello_world_0_syslib/Debug/system_description/../obj/generated_all.mk-t] Error 1 Build completed# ##################################################### In the NIOS error-log I found the following:# ##################################################### !SESSION Apr 11, 2006 14:42:43.119 --------------------------------------------- eclipse.buildId=I200406251208 java.version=1.5.0_04 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE !ENTRY com.altera.ide.core 1 0 Apr 11, 2006 14:42:43.119 !MESSAGE sh C:/altera/quartus51/sopc_builder/bin/sopc_builder --update_classes_and_exit --no_splash -s --projectpathC:/altera/kits/nios2_51/examples/verilog/niosII_cycloneII_2c35/standard !ENTRY com.altera.ide.core 4 0 Apr 11, 2006 14:42:44.322 !MESSAGE Error occurred while updating SOPC Builder Cache. Launch SOPC Builder from Quartus II for more information.# ##################################################### We use Quartus II 5.1 and Windows XP SP2 german version. Thanks in advance for any hint.2 Replies
Hi scanl,
Maybe you encountered the same problem with me. The following posts is FYI. http://forum.niosforum.com/forum/index.php...30&hl=david_cai (http://forum.niosforum.com/forum/index.php?showtopic=3330&hl=david_cai) David - Altera_Forum
I've you been able to solve your problem?
I get the exact same issue (sopc_builder: not found) with Quartus II 4.2 and Nios II IDE 1.1 under WinXP. Taking a closer look gives me the impression that it just can't work as it is... C:\altera\quartus42\sopc_builder\bin\sopc_builder is a shell script and is not seen as an executable by WinXP [of course]. -Pascal
