21 years ago
Build errors in IDE since 4.2 upgrade
Folks,
Anyone upgraded to qts 4.2 yet? I just did and now I cant build. I get this strange error:
[C:/Projects/fpga/antennaHead/QuartusHead/AntennaHeadCPU_sim/dummy_file] Error 2
There is no dummy_file at that location. I tried rebuild all, regen in SOPC builder, etc. There have been no changes to the code. Any ideas?
    Folks,
    Update: I found this error after my project was built...
    Linking RFDev.elf...
    Info: (RFDev.elf) 3817 Bytes program size (code + initialized data).
    Info: 256 Bytes free for stack + heap.
    Creating RFDev.elf.objdump...
    Creating generated_app.sh...
    Post-processing to create onchip_memory_0.hex
    Syntax error: "(" unexpected
    make[1]: *** [C:/Projects/sriv/fpga/antennaHead/QuartusHead/AntennaHeadCPU_sim/dummy_file] Error 2
    make: *** [rebuild] Error 2
    Build completed
    Are you using also using NIOS II v1.1> I thought you have to.
    We need to upgrade to v1.1.
    Otherwise you should not use Quartus 4.2!
    That's correct. This error message will occur when using Quartus II v4.2 and Nios 1.0 sp1. You can either downgrade Quartus or upgrade Nios (I highly recommend upgrading to Nios 1.1).
