16 years agoBuild error!
Hi all:
I added SDRAM mudule to the NIOS II system, and I wanted to test its function.After I builded the system, I wrote a test code. But after I clicked on "build project" in NIOS II IDE, the work interruptted and the software told me that no valid design files found. I am sure that I have added a test file to the project. So this is my problem. Can anyone know the problem and help me! Thank you very much!3 Replies
Hi
Clean the project and try If this doent workout try creating a new project regards M kalyansrinivas - Altera_Forum
2 gowilliam
try to use exaple projects from nios2ide -counter, for exampkle. I think that problems in absense for IDE design files (it wrote about this - "no valid design files found") - Altera_Forum
Thank you all of you! I rebuilded the system again form the beginning,and the error disapeared.But what caused the error? The software?
