21 years agoBuild error : unable to locate Java runtime
Hello I just received my new cyclone dev kit with Nios II 1.1. Before installing the new development tools I completely uninstalled existing quartus and nios versions. I also deleted related en...
21 years agoPossible fix for “Error: Unable to locate Java runtime environment at line 417”
I believe I have a fix for your issue but I would need you to provide me with your direct e-mail address or simply submit a Service request (ATTN: Frank) through the following link since this involves a modified sopc_builder file: mysupport (http://www.altera.com/mysupport) You might also see an issue with your install.ptf not being located. The install.ptf problem is a symptom of the permissions issue that the above error message is caused by. Regards, Frank
