21 years agoBuild error : unable to locate Java runtime
Hello I just received my new cyclone dev kit with Nios II 1.1. Before installing the new development tools I completely uninstalled existing quartus and nios versions. I also deleted related en...
21 years agoThanks, you figured out the solution to the same problem I was having. This problem only seems to occur if you uninstall everything before installing the Nios II v1.1 kit.
After changing the permissions on the .exe files in C:\altera\quartus42\bin\jre\bin everything works fine. The error message "unable to locate Java runtime environmen" is extremely unhelpful. I thought I had a problem with an environment variable or my path or something. Thanks, Terry G.
