15 years agoBuild Configurations and Exclude from Build in Eclipse
Has anyone had problems with using Build Configurations or Exclude from Build in Eclipse Ganymede with a Nios software project? I have a project with a test main.c and an operational main.c in diffe...
15 years agoHi
As you mentioned Eclipse Ganymede, you are using NIOS EDS 9.1. Am I right? Despite that the problem you are describing sounds like the not supported feature of the NIOS EDS 10.0. The feature exclude from build is not supported anymore and is replaced by remove from niosii build. Because it is an Eclipse feature exclude from build is still displayed.But as noted, this is just a matter in NIOS EDS 10.0. Don't know why you can't do it with your version. Maybe you've the feature remove from niosii build as well and it will solve your problem? Though I never used 9.1..... Regards
