SeanAB's avatar
SeanAB
4 years ago
Build Application ends with /bin/bash: make: command not found
Host system: Windows 10 19044
Quartus Prime Lite 21.1
I have gone through the hopos to install WSL, Ubuntu 18.0.4 LTS, and install all the build tools in the Ubuntu terminal.
I have to open NIOS II Command Shell to open Eclipse. I am able to create a project (Nios II Applicaiton and BSP from Template). I created the Hello World small. When I go to build the application, I get the following:
20:24:43 **** Build of configuration Nios II for project simpleapp2_bsp ****
wsl make all
20:24:43 Build Finished (took 102ms)
make is in the /bin folder. How do I fix to get the application to build?
  • ak6dn's avatar
    ak6dn
    On the command line. type which make and what does it return?
    On my WSL it prints /usr/bin/make
    • SeanAB's avatar
      SeanAB
      I get the same result. /usr/bin/make
  • hareesh's avatar
    hareesh
    hi SeanAB,
    please follow the bellow steps and try to build again.
    a. sudo apt update
    b. sudo apt install wsl
    c. sudo apt install dos2unix
    d. sudo apt install make
    e. sudo apt install build-essential
    thanks,
  • SeanAB's avatar
    SeanAB
    Already solved. Missing environment variable.
    • hareesh's avatar
      hareesh
      ok. so i am closing the case.
