19 years agobuild an eCos library error
hi all: when i build an eCos library in 6.1 step 1,some errors occurs : "Error loading the default hardware template 'nios_dev_board': Package CYGPKY_HAL_NIOS@, 7 e...
19 years agoIf you are working with an Altera development board I don't think you should try to bypass the Altera supplied configuration.
My software versions are Quartus II 6.0, SOPC builder 6.0, Nios II 6.01 and working through the 'eCos for Nios II.htm' document worked ok for me.
