16 years agoBug or my ignorance? Regenerating BSP after changing .sopcinfo
So a lot of typing for one question: Did I find a bug or is there an easier way to propagate changes in the .sopcinfo into your BSP and on into the application? Came across this as I was brin...
16 years agoHave you tried to delete the Launch Configuration first and create an new one? Or to refresh "Target Connection"? (Both under "Run Configurations...")
This workaround is described in the Errata-Sheet for an other "Spurious System ID Mismatch Error". Maybe this works in your case as well. Philipp
