20 years agoBug in SOPC?
Why IDT71V416 IP generate 32bit DataBus?Ignore it or I miss something. My quartus and nios 's version is 5.1 In the SOPC ,I chose the SRAM IP IDT71V416 .The SOPC generate 32bits databu...
20 years agoDear Fischer,
I met the same problem (My board only has 256kx16 sram) I built the the component as you said. But when I run NIOS II IDE(6.0) to build a project. I can't find the sram.dat file for simulator use. But when I use the Memory-> IDT71v416 SRAM, NIOS II IDE will generate sram.dat for sumulator. (I had set the program code to sram) Why ?! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thanks for yor help
