20 years agoBug in SOPC?
Why IDT71V416 IP generate 32bit DataBus?Ignore it or I miss something. My quartus and nios 's version is 5.1 In the SOPC ,I chose the SRAM IP IDT71V416 .The SOPC generate 32bits databu...
20 years agouse component editor:
you create a new component, (interface description to an external component, not an IP), you get new signals in your top schematic to connect your SRAM, you have to connect your SRAM to work properly). HDL Files : no hdl files Signals Tab: Name Interface Signal Type Width Direction address avalon_tristate_slave_0 address 18 input data avalon_tristate_slave_0 data 16 bidir cs_n avalon_tristate_slave_0 chipselect_n 1 input wr_n avalon_tristate_slave_0 write_n 1 input rd_n avalon_tristate_slave_0 read_n 1 input be_n avalon_tristate_slave_0 byteenable_n 2 input clk avalon_tristate_slave_0 clk 1 input Interfaces Tab: Name: avalon_tristate_slave_0 Type: avalon_tristate_slave Slave addressing: Memory (use dynamic bus sizing) Minimum Arbitration Shares: 1 Can receive stderr/stdout: No Avalon Tristate Slave Timing: Setup: 1 , Read Wait: 1 , Write Wait: 1 , Hold: 1 , Units: cycles Read Latency: 0 SW FIlesw : no files Component Wizard: Component name: SRAM_512KBx16 Component Version: 1.01 Conponent Group: Memory After generation you will get new signals in the top cpu symbol: cs_n_to_the_sram_512kbx16_0 maybe you get also write_n_to_the_sram_512kbx16_0 read_n_to_the_sram_512kbx16_0 then connect cs_n_to_the_sram_512kbx16_0 --> RAM: \CS write_n_to_the_sram_512kbx16_0 --> RAM:\WE read_n_to_the_sram_512kbx16_0 --> RAM:\OE tristate_bridge_0_byteenablen[1] --> RAM:\BHE tristate_bridge_0_byteenablen[0] --> RAM:\BLE tristate_bridge_0_address[18..01] --> RAM: A[17..0] (two bytes) tristate_bridge_0_data[15..0] --> RAM:D[15..0] (you can share the write and read signals with the tristate_bridge_signals: tri_state_bridge_0_writen and tri_state_bridge_0_readn, by manually changing the ptf file (reinsert component in SOPC!) or using additional logic in top schematic)
