20 years agoBug in SOPC?
Why IDT71V416 IP generate 32bit DataBus?Ignore it or I miss something. My quartus and nios 's version is 5.1 In the SOPC ,I chose the SRAM IP IDT71V416 .The SOPC generate 32bits databu...
20 years agohttp://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Fischer,
Thank you help me again. Does you just change the Pins generated by IP , without the IP inside. I have seen the sch(\niosII\documents\nios_cyclone_1c20),which have two IDT71V416.So I wonder whether the IP work if I change the Pins (SOPC generate as you show)or I don't connect the IDT71V416 properly as the example show. I thought the IP have its specific connection rules outside and it won't work if hardware connection goes wrong or not properly. Thanks again. Tommy.
