16 years agoBug in serial port com
When transferring (using Hyperterminal) 2 identical characters, the second character may get its MSB flipped. For example, sending "FF" may be received as "0x46 0xC6".
Has anybody seen this and know of a solution? I'm using Stratix ver of NIOS board. Thanks.2 Replies
There is a problem with your design.. I often working with standard UART and Fifoed_UART and there is no such problem for me more than 4 years..
It might be that you baud rate is slightly out, and that the wrong bit gets sampled - in theory this should generate a receive framing error, but those aren't always reported to apps.
The byte will be sent LSB first, so you should be able to work out what is being mis-sampled. Remember the async byte pattern is 10 bits long (a zero before the byte and a one after it).
