16 years agoBug in serial port com
When transferring (using Hyperterminal) 2 identical characters, the second character may get its MSB flipped. For example, sending "FF" may be received as "0x46 0xC6". Has anybody seen this and kn...
16 years agoIt might be that you baud rate is slightly out, and that the wrong bit gets sampled - in theory this should generate a receive framing error, but those aren't always reported to apps.
The byte will be sent LSB first, so you should be able to work out what is being mis-sampled. Remember the async byte pattern is 10 bits long (a zero before the byte and a one after it).
