21 years agoBug in NIOS2 GCC ?
Could this be a bug in the NIOS2-GCC ? char testsub(void) {
return __builtin_ldbio (0x1000);
} Generates the following Assembly code (Using -O2 and -fomit-frame-pointer): movi r3...
21 years agoHi Sgan,
<div class='quotetop'>QUOTE </div> --- Quote Start --- With this code, you can be sure you get wrong results...[/b] --- Quote End --- You are correct. Which is why I recommend not using the defective builtin. <div class='quotetop'>QUOTE </div> --- Quote Start --- Thank you very much for finding this issue in the compiler. You are correct that there is a bug here, __builtin_ldbio() should be translating to a ldbio instruction, not a ldhio. This issue will be fixed for the next release of the compiler. If this is causing you a particular issue, I recommend either using __builtin_ldbuio() and sign extending it, or using extended assembly statements.[/b] --- Quote End --- Let me elaborate on the above. What I recommend your code look like is this:int testsub1(void) {
char x = __builtin_ldbuio ((void *)0x1000);
return (int)x; // sign extend x
} Or using asm statements: int testsub2(void) {
int x;
asm ("ldbio %, 0(%)" : "=r" (x) : "r" (0x1000));
return x;
