BSP newlib building failure
Hi @ScottHu,
Thank you for posting in Intel community forum and hope this message find you well.
Currently we are experiencing some issues with WSL 1 upon window updates.
However available patch has been release to solve this, please refer to the KDB and installed the relevant patch according to your Quartus version.
Warm regards.
- BoonBengT_Altera5 years ago
Moderator
Hi @ScottHu,
Hope this message find you well, by any chances did you managed to look into the proposed recommendation steps above and does it work?
Warm regards.
BB
Moderator
Hi @ScottHu,
Hope this message find you well and good day, as we do not receive any response from you to the previous clarification that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
- TK995 years ago
I'm still facing this problem.
Using Win10 Pro 10.0.19041
Still using QUartus 20.1 Pro ; Patch 20.1-0.49 installed
Have you any suggestions?
Best regards
Tim
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.It was created by configure, which was
generated by GNU Autoconf 2.64. Invocation command line was$ /mnt/c/intelFPGA_pro/20.1/nios2eds/bin/gnu/src/newlib-3.1.0/configure --enable-multilib --enable-newlib-nano-malloc CFLAGS_FOR_TARGET=-g -Os -ffunction-sections -fdata-sections CXXFLAGS_FOR_TARGET=-g -Os -ffunction-sections -fdata-sections --prefix=/mnt/e/TIM/00_BAYTEK/WARP_REF/udx10_warp_ea_0.1.20210308/udx10_warp/software/vip_control_bsp/newlib --target=nios2-elf
## Platform. ##
## --------- ##hostname = DESKTOP-SCM7FSJ
uname -m = x86_64
uname -r = 4.4.0-19041-Microsoft
uname -s = Linux
uname -v = #488-Microsoft Mon Sep 01 13:43:00 PST 2020/usr/bin/uname -p = unknown
/bin/uname -X = unknown/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknownPATH: /mnt/c/intelFPGA_pro/20.1/nios2eds/bin/gnu/H-x86_64-mingw32/bin
PATH: /mnt/c/intelFPGA_pro/20.1/nios2eds/sdk2/bin
PATH: /mnt/c/intelFPGA_pro/20.1/quartus/bin64
PATH: /mnt/c/intelFPGA_pro/20.1/quartus/sopc_builder/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /mnt/c/Windows/system32
PATH: /mnt/c/Windows/System32/Wbem
PATH: /mnt/c/Program Files/PuTTY/
PATH: /mnt/c/Users/TK/AppData/Local/Microsoft/WindowsApps
PATH: /mnt/c/Users/TK/.dotnet/tools
PATH: /mnt/e/Intel/Quartus/20.4/modelsim_ae/win32aloem
PATH: /mnt/e/Intel/Quartus/20.4/modelsim_ase/win32aloem
PATH: /mnt/c/Program Files (x86)/Silicon Laboratories/ClockBuilder Pro/Bin
## Core tests. ##
## ----------- ##configure:2320: checking build system type
configure:2334: result: x86_64-pc-linux-gnu
configure:2381: checking host system type
configure:2394: result: x86_64-pc-linux-gnu
configure:2414: checking target system type
configure:2427: result: nios2-unknown-elf
configure:2481: checking for a BSD-compatible install
configure:2549: result: /usr/bin/install -c
configure:2560: checking whether ln works
configure:2578: result: no, using cp
configure:2586: checking whether ln -s works
configure:2593: result: no, using cp -p
configure:2597: checking for a sed that does not truncate output
configure:2661: result: /bin/sed
configure:2670: checking for gawk
configure:2686: found /usr/bin/gawk
configure:2697: result: gawk
configure:4152: checking for gcc
configure:4182: result: no
configure:4245: checking for cc
configure:4292: result: no
configure:4348: checking for cl.exe
configure:4378: result: no
configure:4402: error: in `/mnt/e/TIM/00_BAYTEK/WARP_REF/udx10_warp_ea_0.1.20210308/udx10_warp/software/vip_control_bsp/newlib-build-tmp/smallc':
configure:4405: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
