10 years agobsp compilation error. #scrubbing should be enabled!
I was following some step to generate my own preloader, the generation compelted, while the compilation failed with the message above.. how to fix this?
it worked already. why is this need to be enable but not by default?
i guess you have been over read earlier, as the guide had been reminding user to check this item up for the generation.
