10 years agobsp compilation error. #scrubbing should be enabled!
I was following some step to generate my own preloader, the generation compelted, while the compilation failed with the message above.. how to fix this?
10 years agooh this... can you reopen your bsp -editor again and enable the SD RAM scrubbing? then proceed with the compilation again. The hand of had enabled this feature earlier.
