Arthur_Davidov
5 years agoBSP build - Configuring BSP search path
Hi, I have a problem same as described here and the suggested solution is to edit configuration path. In " Nios II Software Developer’s Handbook " NII5V2-13.1 p.42 there is an explanation for '...
- 5 years ago
Hi!
yes , that is correct.
an example of this is :
$ nios2-bsp-editor.exe --librarian-path=/mnt/c/temp:$
after running this command with the new path, the BSP editor search path window will open and you'll see the new search path updated.
please let me know any questions you may have.
-Eliath Guzman
Eliath_G_Intel
5 years agoHi!
-Eliath Guzman
