19 years agobridge between Altera Bus and Wishbone Bus
recently I am develping a project which will use seveal IP base on Wishbone
and I don't know how to develp a bridge between Altera Bus and Wishbone Bus is there anybody who know how to do such a thing?2 Replies
Hi lmxue518,
> is there anybody who know how to do such a thing? I developed a Wishbone-Avalon bridge to use with the OpenCores PCI bridge ... It's pretty straight forward as the two buses are very similar. > and I don't know how to develp a bridge between Altera Bus and Wishbone Bus First, read (and understand) the Avalon and Wishbone bus specifications: http://www.opencores.org/projects.cgi/web/...e/wbspec_b3.pdf (http://www.opencores.org/projects.cgi/web/wishbone/wbspec_b3.pdf) http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) If all you need is an Avalon master to Wishbone slave you should have little trouble. It really boils down to how you want to map Wishbone ACK, ERR & RTY to the Avalon waitrequest. Regards, --Scott - Altera_Forum
thank u very much.
all I need is just an Avalon master to Wishbone slave,so it turns to be easy as you say.
