22 years agoBreackpoints on the newlib source code
I have a small problem using NIOS II IDE. Suppose to create a Hello world application. Open the instruction set simulator, and start debugging the application. I would like to put som...
22 years agoYou need to create and Advanced project in the IDE which points at the newlib source code and then you're in business.
To do this from the IDE go File->New->Project Select Altera Nios II Advanced C/C++ Project and then the location for this is underneath your install in the directory altera\kits\nios2\bin\nios2-gnutools\src\newlib
