20 years agoBootloader size
Hi! I'm writing a bootloader for NIOSII to load my application from an rs232 uart into SDRAM. What I'm trying to do is pretty much the same as described in this topic: http://www.n...
20 years agofor information:
simple bootloader: you can write programs with the same quartus and SOPC settings and store these programs at different locations in flash. (Reset Address in flash at 0x00000000) I have a c_bootloader at add 0x00000000 in flash it can receive programs over uart (ymodem) and writes it into flash. e.g I have c_bootloader at add=0x00000000 in flash prog1 at add=0x00100000 in flash prog2 at add=0x00200000 in flash from the c_bootloader i can execute e.g. the following code to start prog2 from flash void (*pBoot)(void); // declare function pointer int startadd; // declare startaddress as integer .. startadd=0x200000; pBoot=(void*)startadd; pBoot(); // jump to new altera bootloader in flash the trick is, that every program in flash has the small altera_bootloader in front and copies itself from flash to ram and starts from ram. So the main (difficult) job is done from the altera_bootloader. the c_bootloader is just a noraml c-program, no assembler necessary. you can use the same settings of quartus and sopc builder for the c_bootloader and your other programs. see also topic How can I start different programs from flash in general discussion forum http://www.niosforum.com/forum/index.php?s...0&hl=bootloader (http://www.niosforum.com/forum/index.php?showtopic=200&hl=bootloader)
