11 years agoBooting uClinux from SD-Card possible?
Hello, i am new on developing with Nios II an uClinux. I have got an DE2-115 Board and was able to set up a Nios II Processor, build the kernel and run it. Now i wonder if it is possible to p...
11 years agoThank you for the reply.
Your project is complex, so I have a few questions: 1. I added a "SPI (3 Wire Serial)" component to my Qsys-Design to connect to the mmc/sd. Are there more changes to do there? 2. When I use the "sopc2dts" tool, are there any changes to make? 3. Due the "make menuconfig" witch options shell I select? 4. How do I prepare the SD-Card? Witch partitions are needed and how big should i make them? 5. What Files do I need on the SD-Card? When I make the Kernel I get the "zImage" but what to do with it and do I need the "u-boot" and how do I do that? EDIT: I found this document (http://uuoc.org/uclinux_nios2_custom_hardware.pdf) and did all the steps. But I cant see anything on the console. I guess either the CPU can't read from the SD-Card or doesn't now to read from there :/
