17 years agobooting out of flash and starting out of DDR2
I have a problem with my DDR2-RAM. I want to boot out of my Flash Device and run the uClinux in my DDR2. The Problem is, that my DDR2 is storing some initalization data in the first regions of t...
17 years agojust a question: did you try another (type of) memory? copy the image to an sram or onchip (i do not work with uClinux, so i don't know how much memory space it needs to run from).
i had some issues when i set the start address of the nios ii to ddr2 ram. after a hardware reset the nios II did not run since some of the data was overwritten by the ddr2 controller.
