17 years agobooting out of flash and starting out of DDR2
I have a problem with my DDR2-RAM. I want to boot out of my Flash Device and run the uClinux in my DDR2. The Problem is, that my DDR2 is storing some initalization data in the first regions of t...
17 years ago --- Quote Start --- I start out of the flash and unzip it in the ddr2, but i need a offset to not erase the inital data. or i need to know where the calibration data is stored and how to copy it to the flash. --- Quote End --- okay, this is a starting point. i have some further questions. the calib data you're mentioning. do you mean with that the data which is written by the controller? or do you mean calib data which you have written to start special actions defined by yourself (or uClinux or something like this)? if you mean the calib data from the controller, then you can overwrite them without care. they are just for calibration at startup time. so you could easily copy the uClinux-image and start it from ddr2. schafrichter
