19 years agoBooting Nios2 from custom NV-RAM
I tried this question on comp.arch.fpga newsgroup - no answer. Here is probably a better place to ask. Preface: When the Nios2 CPU reset vector points into Altera-provided CFI flash the SOPC ...
19 years agoThan you may modify the Altera provided component to satisfy your needs (I do not know how to exactly do that, but you should probably know some scripting language). Or manually modify the .ptf file, it will not open gracefully in SOPC builder, but should be OK when you finish the hardware and focus on software.
IzI
