Booting NIOS II/e from EPCQ-L on Cyclone 10 GX Dev kit
Sorry to hear your experience.
Let start with what are the other thing your observed during the failure Nios II Boot?
Are you using the XIP or boot copier method on the EPCQ booting?
Also, we have a design for Cyclone 10 LP, you may migrate it to your device and recompile:
"Let start with what are the other thing your observed during the failure Nios II Boot?"
I follow the instructions as listed in the document I linked above. The NIOS does not blink the LEDs as I programmed it to do. I have no other observations. If you have knowledge of how to debug further, let me know and I can provide more information.
"Are you using the XIP or boot copier method on the EPCQ booting?"
From my original post "Scheme: Active serial x4, boot copier method"
"Also, we have a design for Cyclone 10 LP, you may migrate it to your device and recompile:
I will attempt to convert this design and use it.
