21 years agobooting multiple nios2 from SDRAM
Hi Any advice..? I have a S260ES dev board and what I want to do is have 2 nios2's boot and run from the top 2Mbytes of the installed 16Mbytes SDRAM (located at 0x0 to 0x000FFFFF). ...
21 years agoHi Cheers for the reply..
Im using 4.1 and 1.0.. I had set the tcp ports to be different..! What I think I had done wrong was I only had one system timer and was tring to use this for both processors.. Duh!! (one would clear the interrupt and the other would hang waiting for it!!) I have just got copies of 4.2 and 1.1.. im going to have a play today to see what improvements there are w.r.t multi-proc systems (I actually have 7 niosII's in my design so im hopping it will make things a little easier.)
