20 years agoBooting from EPCS4
Hi, We are developing the software for a custom board we designed and manufactured, so it's time for "burning" the software into the EPCS. We haven't included any CFI flash device in th...
20 years agoHi VLorenzo,
> We haven't included any CFI flash device in the design, only an EPCS4 for > storing the FPGA configuration (EP1C12) and a program that should run > at start-up. Maybe, you should add cfi flash device to your flash programmer design, though you have no cfi flash in you project. You can refer to http://www.altera.com.cn/support/ip/processors/nios2/ips-nios2_devkit1.1-er.html#ideflash In Flash programmer failures on custom boards parts, <div class='quotetop'>QUOTE </div> --- Quote Start --- The flash programmer may fail if the custom target board does not contain a CFI flash component. Even if the board contains only an EPCS configuration device and no CFI flash, the target board system must contain a CFI flash component. Workaround: Add a CFI flash component to your target board in SOPC Builder. You do not need to connect the flash signals to pins at the top level--you can leave them unconnected.[/b] --- Quote End --- I hope this can help you. LiangYi
