20 years agoBooting from EPCS to SDRAM with Q-II 5.1
We have a Cyclone-II FPGA (EP2C35F484C6) with a NIOS system and an EPCS64 Flash, where is the configuration of the FPGA and the programm code. We have the reset address pointing at this EPCS device, ...
20 years agoHi jlistan,
Does your application work (running in SDRAM) when you use nios2-download? If not, you should check your SDRAM configuration. Regards, --Scott
