21 years agoBooting from EPC4
Hi all, Can I ask - is there a simple way to generate the programming file necessary to write to my EPC4 device? Basically I want the solution that gives me a programming file consisting of f...
20 years agoI had the same problem with the quartus i belive what you have done is to delete the deley_rest_block
if so that is a mistake. try to add it back , if you need the vhdl file that define this block look for them in the example file of the standart project , you will need to add a PLL and to tie all the input and output of the the system to the right pins of the cheep , look at the standart project for example
