21 years agobooting a dual NIOS II
So, I've been working on this 1S10 dev board. I've twice gotten dual core builds that loaded from different addresses on flash. Last time I added other items that pushed the size (LEs)...
21 years agoHi all !!!
I have a dual Nios II core system with on_chip_memory1, on_chip_memory2 and flash. I prepared also 2 C++ Application in Nios II IDE, for cpu1 and cpu2. How can I use the options to build a project that loads from different addresses on flash, transferring the two codes from the flash to each on_chip_memory??? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif Is it possible?? Bye!
