19 years agoBootargs from U-Boot for NIOS2
I had a NIOS2 based custom board running uClinux Kernel v2.6.16. This board also uses u-Boot as it's boot loader and I'm trying to get the "bootargs" within u-Boot passed down to the Kernel. ...
19 years ago --- Quote Start --- originally posted by cypher+nov 3 2006, 04:32 am--><div class='quotetop'>quote (cypher @ nov 3 2006, 04:32 am)</div>
--- quote start ---
<!--quotebegin-hippo@Nov 2 2006, 01:56 AM patches added.
please check dasuboot and uclinuxdist on nios wiki .
i didn't try out, yet.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19087)
--- quote end ---
--- Quote End --- Hippo, Thank you very much. I was about half way through very similar changes, I was getting stumbled up with the SP movement. I very much appreciate your work. Thanks again.. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19113)</div> [/b] --- Quote End --- update again patch ver 12, relocate stack of zimage to 64K above _end instead of at the top of sdram. now the u-boot,zimage and vmlinux should not cluster each other.
