13 years agoboot NIOS from EPCS flash and use SDRAM to store instructions and data
Hi! In the qsys I have: 1. Clock Source 2. On-Chip Memory 3. Nios II Processor 4. System ID 5. JTAG UART 6. EPCS Serial Flash Controller 7. PIO 8. SDRAM Controller I want to use...
13 years agoI'm using the sections as you can see in the attached screenshot. The instruction master must connected to sdram in qsys.
But if you can debug code running from sdram it should connected already. Jens
