21 years agoBoot from EPCS
Hello, I have a problem booting from EPCS. Using flash programmer, I wrote FPGA configuration data & elf file to EPCS, but booting fails. The following is my flash programmer setting: --...
21 years agoThank you Jesse,
It seems that (2) was my problem. However, (1) was also a problem I realized before posting here. Until I got your answer, I counld't figure out why "Program software project to flash memory" didn't have any pull down list to specify the device or the offset. I didn't think that NIOS II IDE refers to any script made by QuartusII or SOPC Builder(I hope I'm correct..). But now the problem is solved. Once again, I appreciate your prefect advice!
